1sttimeboater
Thread starter- Joined
- Jul 30, 2007
- 8
I have a 1997 Rinker with a Mercruiser 5.7L and have replaced the Thunderbolt Ignition with a HEI. The problem that I have been having is that sometimes I do not have any spark. I replace the module and get the spark back, so I originally thought the problem was a bad module. After further investigating, the modules are still good. This weekend I disconnected the tack to make sure it was not the problem, but the problem persisted.
I have a white/green wire that comes from the shift detent? wired to the tach output on the HEI, is this correct? If it is not hooked up this way, the boat will not shift out of gear back to neutral.
The last time I had no spark I simply removed the wire from the module to the pick up coil, plugged it back in and the boat started. Could the problem be in the pick up coil?
I am lost and very frustrated in having to pull the cap to get the boat to start.
Thanks for any help
Thanks for any help
