mnboater26
Thread starter- Joined
- Jul 25, 2007
- 5
I purchased an old boat, and then found out that it was even older than I had originally been told, 78 but really a 61, and the motor that was on this craft is a 1961 johnson V4 75 HP Electric. Needless to say the Old boat just needs more work that I am looking to put into a project right now, so i am taking the motor that runs well and placing it on a newer boat(71 Larson). The issue I am running into is that this older Johnson's electrical system (wire harness running from the motor to a box mounted under the rear splash deck, containing the starter soliniod and other components that are required for the motors charging system) is not compatible with the newer boats "plug and play" setup.
Is it a waste of time to try and use this box and try and integrate it into the already in place system that is in the newer boat? or does anyone have any info on a way to convert whats in that box to what I need to plug into the new boats setup.
ANY info on this would be a great help..
Thank you all for looking
