ddrieck
- Jul 12, 2007
- 655
Have Merc 500, 50 horse, S/N 496513A on a 1979 16" Starcraft. I have pulled the carbs, taken them apart, and cleaned them. Reassembaled with the same settings on the needle screws. Did a de carb in the driveway hooked to a hose and earmuffs (smoked out the nosey nieghber) Installed new clean portable 6 gallon tank, fuel line, sweeze bulb, and spark plugs. Starts fine, idles smoothe but will not build enough RPMs to break over to plane out. I get a very very slight stumble at full throttle. Back it of just a bit and stumble goes away but still will not plane out. Could this be a lack of fuel volume and pressure? Should I rebuild the fuel pumps?
