Re: Ignition switch Johnson 70 hp -79
There are no carburetor adjustments pertaining to the fuel/air mixture. Those brass jets simply screw down until they bottom out and seat. The cover screw for the top idle slow speed jet should have a red washer in back of it, and it should be tightly seated.
Did you acyually remove and manually clean those jets, especially the fixed brass high speed jet that's located in the bottom center portion of the float chamber..... in back of that screw at the bottom front area of the float chamber? If not, do so as a clogged jet will result in exactly the problem you're encountering.
Another thing..... that cam that glides into the carburetor throttle cam roller, there's a scribe mark on the cam. The throttle butterflies must just start to open when that scribe mark is dead centered with the roller, not before or after.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
