brewmister
Thread starter- Joined
- Jul 21, 2007
- 37
I just bought this boat has a 93 70hp yammie and got it out to test. It took 20 minutes at 2100 rpms to get the overheat buzzer to go off but it only takes 3-5 minutes to reset and I can go again if I want. has strong pee hole. I first ran it in a barrel of Salt Away about 6 or 8 times. no help. I took the pressure tube off the corroded gauge and there is not pressure. Took t-stat cover off and no t-stat so I replace it with a new one nad got a little pressure back from tube. just got out and it took a little longer but overheated. He said he just got the water pump changed (dont believe that) but its pissing good. Any suggestion Before I change the water pump and when I do should I change the whole thing with the kit?
How much water should come out of the presssure gauge tube?
When I replace the gauge what should the water pressure(s) be?
I am afraid the ports are scale over with salt deposits but dont want to jump to any conculsions.
Thanks
Thanks
