Tilt & trim problem on 90hp Yamaha
Marc III
My tilt & trim has been a little noisy (squeeky actually) lately but worked perfectly. Today it hesitated to go down at first, (the motor was working) and then it lowered and raised normally a couple of times before it failed again fully raised. I checked the fluid, it was full but a little foamy. I turned the release screw to lower the motor manually then turned it back counterclockwise. Then the motor wouldn't raise, it would pull down further, but not go up. I drained it the best I could and filled it with fresh ATF and it didn't help.
I decided to remove the unit for closer inspection, and it doesn't seem to come out from between the mounts. I got the center ram and the six bolts out easily. It will raise maybe an inch or more, but not enough to come out. Will I need to remove the engine from the boat? I had removed a T&T unit from an OMC 90hp before and the Yamaha unit looked like it would come out the same way.
What should I do when (or if) I get this thing off? Should I do some further testing before
that point?
It may be unrelated, but the boat got caught in a heavy rain yesterday and the splashwell drain is located right behind the T&T unit. I plan to add one or two more and plug that one.
Oh yeah, it's an 1988 model.
JUSTINTIME
Re: Tilt & trim problem on 90hp Yamaha
shoot me an e-mail i have factory manual
Marc III
From doing a search, I learned that to remove the unit I need to support the engine and remove the starboard mount completely. Why the starboard side? Am I looking at a new pump or what?
JUSTINTIME
slides out that way
Marc III
I've got a few OMC manuals from that era. Is the Yamaha unit basically the same? I did discover the manual release screw works in the opposite direction. I'm hoping that a disassembly and cleaning followed by some fresh ATF will fix it. Anybody done this recently?
4fish
The set screw that allows for manual over ride must bescrewed all the way and tight. after i did this mine worked fine
