140 Tohatsu
Jeffrey Hillegass
Re: 140 Tohatsu
No trim motor burnt up so when I open up motor casing black oil ran out. I thought that the seal had leaked and ATF got in. But the guy who rebuilt it said the seal was fine.I have been bleeding air out of system manualy the way the book says. But still have a lot of air. Is ATF supose to start to come out of manual valve because I am not getting that. Now I need to rebuilt motor again from trying to use power trim which by the way is super slow and has burnt up , so what am I doing wrong?
Jeff
TOHATSU GURU
Re: 140 Tohatsu
Jeff,
It is normal to get oil out of the manual release when you bleed it. But, I can't tell you what's wrong except to say that you have a leak or you couldn't get air in. Working the unit up and down should expose the leak, but not always. You really need to get this in to someone in your area who is used to working on PTT units.
Jeffrey Hillegass
Re: 140 Tohatsu
i am not getting any oil out of my manual release valve. i just thought i should be. but for some reason i cant get the air out of the system manually. ive asked several boatyards and i cant even get anyone to look at this outdrive.Last year number one piston burnt up and nobody would work on it then neither. so i bought a manual and rebulit it myself. when i talked to mechanics all they say is we know nothing about those tohatsus motors. ive contacted three tohatsu dealers and all they want to do is sell me parts but will not give me any information. im about ready to throw this thing in the bay. do you know who i can contact to report these tohatsu dealers who are the rudest people you want to meet. Thank you.
Jeff
TOHATSU GURU
Re: 140 Tohatsu
The number to call is 972-323-6003 and ask for anyone in management. Normally you will get oil out valve, so if your not you must be leaking down quickly. What's your zip code?
TOHATSU GURU
Re: 140 Tohatsu
In this case, leaking down means that you have an air leak that is preventing the system from operating correctly. Also, the following four dealers are in your area.
Company Tradewinds Marina Inc.
Address 412 Armstrong Rd.
Baltimore MD 21220
Phone 410-335-7000
Fax 410-335-7009
Distance Approx. 8 Miles
Company Kane Marine
Address 8663 Fort Smallwood Rd.
Pasadena MD 21122
Phone 410-360-7778
Company Maritime Solutions, Inc
Address 306 Second Street
Annapolis MD 21403
Phone 410-263-1496
Fax 410-263-1531
Website http://www.inflatablexperts.com
Distance Approx. 19 Miles
Company Sarles Boatyard and Marina
Address 808 Boucher Avenue
Annapolis MD 21403
Phone 410-263-3661
Fax 410-263-3771
Website http://www.sarlesboat.com
Company Annapolis Boat Sales, LLC
Address 337 Pier One Rd., Suite 204
Stevensville MD 21666
Phone 410-604-6962
Fax 410-604-6964
Distance Approx. 21 Miles
Jeffrey Hillegass
Re: 140 Tohatsu
Thank but the first two are the rude ones. The guy at Kane all I did was say hi my name is jeff what is your name and he hung up. When I called back he would not give me his name. I know you are a dealer but I got to tell you some of these guys are RUDE. Not you
THANKS
Jeff
Ps.Why do you think there was oil in my electric motoer the first time I took it apart? Do thay come with oil in them?
