Good Practice?
G
Guest
Guest
I did some searching through the forums and couldn't find anything, even though I bet it has already been posted...
Does anyone regularly run their two stroke outboard "dry" after a day out on the water to clear the gas/oil out of the carb? Is this necessary if the motor is used every 1 or 2 weeks? I haven't been doing it, a buddy recommended that I unplug the fuel line and let it run until it dies after every use?
He specifically said that it would keep the carb jet from getting gunked up..
Replies are appreciated.
Thanks.
BoatBuoy
Re: Good Practice?
You didn't search enough. There's volumes written about this. Some believe it should be done, some don't.
Just use fuel stabilizer and don't worry about it.
jimyoung
Re: Good Practice?
I have always done it....fuel does go bad.....have never had a starting issue on the 4 different motors I have had over the years...........my 1956 evinrude is a new venture for me......have alot to learn about it.......
Silvertip
Re: Good Practice?
Running a two-stroke engine dry means that each cylinder does not run out of fuel at exactly the same time. And if one or more cylinders run dry, that means no fuel -- hence no lubrication either. Secondly, running an engine out of fuel does not fully empty the carb float bowl so some fuel remains. In addition to the fuel that remains, you have now allowed more room for air. Just treat the fuel and forget this nonsense -- with one exception. That would be a portable engine that must be layed over for transport. There it would make sense to at least rid the engine of most of the fuel. Treated fuel can be left for months with no damage or gunking.
G
Guest
Guest
Re: Good Practice?
Thank you for the informative post Silvertip!
What fuel treatment additive do you recommend?
bogggar1
Re: Good Practice?
I concur with Silvertip... running it out of gas/oil mix is harmful to ur vital engine components. :cool:
tashasdaddy
Re: Good Practice?
Most of us recommend using Seafoam, treatment. keeps a clean carb clean.
JB
Re: Good Practice?
The practice seems harmless in single carburetor engines, but with multiple carbs I think it risks damage in the cylinders that run dry first.
I have always done it with small, portable engines that will be removed from the transom.
I never do it on multi-carb engines.
