Mercury 115 Oil Injection System
dnl94
I Just Purchased A 95 Bass Tracker With A Mercury 115 Oil Injection System On The Motor. Some People Has Said The Oil Injection Has Had Problems And That I Should Purchase A Kit To Close The Injection System Down And Just Mix My Own Fuel 50:1 . Is This Something I Should Concern Myself About Or Is The Oil Injection System On These Motors Ok?
gss036
Re: Mercury 115 Oil Injection System
My personal opinion is simple. If it is not broke, why fix it. I have been a Merc oil injection since 1989 w/o any major problems. It is a very reliable system.
pops
I have a 95 model 115 Mariner (same motor) with oil injection that I bought new and have had no problems.
The only issue is that there is no warning light or buzzer if the oil pump fails. There is a buzzer for low oil in the reservoir, but that's one of those things that you already have control over!
I agree with gss036 about leaving well enough alone.
dnl94
Thanks Guys , I Do Agree, If Not Broke Don't Fix It. Thanks Again.
j_martin
The oil warning module keeps track of the oil pump. If it quits sending pulses while the engine is running, which signal it gets from a switchbox, it'll let you know.
I mix about 150:1 with my tank gas, just as insurance. It is possible to break the oiler at wot and hurt the motor before you can react. A little in the gas is just insurance at very little cost.
dbm_nj
Can the oil injection system pump too much oil into the engine? At the end of last season I started to see quite a bit of blue smoke coming from my engine at start-up and for a few minutes thereafter. :(
gss036
There several 2 psi check valves in the system, chances are one if malfunctioning allowing oil to seep by under pressure. Do a search and you will find many posts on this subject, read through and get an understading of the system and then do the troubleshooting.
