1984 Omc I/o (part two-long)
Greetings Gentlemen-
I called a second technician today and he gave my new (used) boat the once over. He told me that the transom seal would be a tricky, but important job as several of you mentioned. I asked him if I should order the one off ebay as was suggested, and he told me not to since if he doesn't have it in stock he can get it the same day for about that same price. He also mentioned that the reason the alternator belt broke in the first place was because the part of the alternator that the belt touches is rough. Not sure if he wants to replace that part or the alternator itself...
I asked him about the motor looking like it is pushing back through the transom causing excessive wear to the seal, and he didn't see a major problem.
He did tell me that the motor is not bolted down securely though, and that he will have to pull it and re-fabricate a secure foundation- see pic of rusty loose bolts...
He will tally up the total of the work he needs to do and call me tomorrow. He and his wife (a friend of mine) are leaving for a vacation all next week, so he told me I might not here from him until he gets back.
If this job is less than $2K I will be (somewhat) happy since I don't have much into this boat and heavy duty trailer. What do you suppose my chances are? Here's a pic of the boat itself from the outside so that maybe you'll agree that it's not a total P.O.S....but then again I'm a cadet.
Thanks to anyone who has already; and will now respond, Arty.
