89 johnson 88 spl oil leaking down outside of motor
moonspell
A day after my last outing, I noticed a good amount of black sticky oil had run down one side of motor. It was comming from under the plastic collar under the engine, i took the collar off an couldn t see where exactly it was comming from, lt was comming through the area where the mounting arm connects to themotor.Looking from the top around the motor i saw no oil.My worst case thought is a power head seal or gasket.thank you.
tashasdaddy
Re: 89 johnson 88 spl oil leaking down outside of motor
did the motor run like it was suppose to that day.
moonspell
it ran good like it always had.the oil was sticky after a day, i assume it was thin when it first ran out.
reeldutch
was the oil clean or black?
apaulos
On my 93 88SPL, I've had a dark dirty oil running straight down from the power head right below the carbs. I had the engine raised 90 degrees to the stern (steering wheel dead center). A week before, I had sprayed down the block with wd40 or something similiar. So I assumed it was the spray oil leaking out. But it looked more like burnt black dirty two cycle oil. I need to chase this down when I have a chance.
BigRed48
I have a '96 112SPL, and I had the same problem, after I miscalculated and put too much oil in my gas. I had a mechanic tell me that the excess oil that doesn't get burnt somehow makes its way out and down the shaft. Not sure I buy that explanation, but used that gas up measured correctly and don't have that problem anymore
reeldutch
hate to say it but i believe you have a bad powerhead to adapter gasket.
does the motor run good?
Swampmouse
Yep, it's a powerhead gasket. I had the same problem with my 83 Johnny 115. Thick black oil running down the side of the motor - right from where you describe it. This black oil has a definitive blackness - not like unburnt ful that comes out of the carbs when the motor is raised. I did a rebuild and finally got to the root of the problem.
Sorry for the bad news, but it really should not be too hard to pull the whole powerhead , replace the gasket. and set it back. Be very careful when re-setting the powerhead as it can be very easy to pinch the gasket and ruin it. You should have a helper with you to do this.
SM
moonspell
when i change this gasket is there anything else i should replace since ill have the powerhead off, or can i get just the one gasket.
moonspell
i took the powerhead off today, and it was that gasket. thanks
Swampmouse
I do not know if you are going to be able to get just that one gasket - but maybe. I got a whole kit of gaskets as i was doing a total rebuild.
SM
