Re: Johnson 1972 50hp top end power loss
OK, here is the status:
I inspected the stator and it appears to be very clean, non-oozing, with no visual defects whatsoever. I took the boat "up north" (northern Wisconsin) and did the de-carb process recommended in the link in this thread. I used 3/4 Gal of gas (regular unleaded 89 octane with up to 10% ethanol), 1 16oz can of Seafoam and 3oz of 2 cyl oil. Can't avoid ethanol gas anymore, even up north. Anyway, started an ran it at very low speed for 15 minutes, shut it off and started after 15 minutes. Tons of thick white smoke when repeating the process the second time. Ended up doing this cycle 6 (yes SIX) times until the thick white smoke subsided. I had to mix another batch of the above to finish the job. Took the boat for a run and it did 28 mph
on the speed gauge compared to 23mph last year. great improvement.
I also checked the timing and found it was advancing only 15 degrees at full advance. I adjusted it to 19 degrees which is what the shop manual spec is. This did not increase top speed, but it did seem to give better response over the operating range and more even power throughout. Even on rougher water the speed did not seem to drop more than 1mph at top end or lose much acceleration.
The other thing I tried is tilting the motor back one notch. This helped the boat come out of the hole better and it planed with the bow just slightly up which per the manual is correct. It used to take longer to get to plane and planed more at a level position than with the bow slightly up. No speed increase with the tilt, just better out of the hole.
Anyway, the Decarb process was the big contributor, giving 5mph from last years 23. The timing seemed to help acceleration as well as the tilt adjustment, but neither of those 2 items made any change in top speed. I also probably lost 1-2 mph over last year since the gasoline up there now has 10% ethanol compared to none last year.
Overall I was very happy with the results, and
thanks to all that contributed suggestions, this is a really great group with vast knowledge
. My goal was to get to 30mph but still this was a great improvement. I was able to pull a tube at 20mph and the kids had a blast (that got them up to about 30mph on crack the whip) Since the boat is a 1972 with a double hull, I am going to inspect the foam yet because I suspect there could be some water trapped in the hull layers within the old foam. After a core sample, I will report back and maybe get some improvement there with new foam. Any suggestions on how to go about that? I can work with fiberglass, just don't know what foam to use.
Reb
