89 5.7 losing p/s fluid
delsol
hi i got boat back from the shop with all kinds of problems. but i noticed that i am losing p/s fluid. they installed new p/s lines . old pump. i cannot see a leak. question could it leak from a rack like a car???if i lose all the fluid will it hurt to drive it without the powersteering??
Re: 89 5.7 losing p/s fluid
Ayuh,.......
Ayuh,........ It'll turn Real Hard,+ Then you'll Burn Up the Pump.........
Don S
If you can't find any leaks, pressure check the PS oil cooler. It's probably pumping the oil into the cooling water.
delsol
don its a fresh water cooled open system i guess its called. its looks like a gm car pump with lines going to a rack. how could it escape to cooling system?? i think i seen a third line??
bob
delsol
also don i never seen an oil cooler . where would that be
bob
delsol
also bondo if i run into a problem can i disconect the p/s pump temp and still drive the boat. this is my first with p/s 19'4" 2700 lbs
bob
Coors
behind the engine, on a coolant line, you will see a small thing that looks the size of a check valve.
that is it, and it also needs draining for winter.
Under, or behind the motor, In the water line from the Outdrive to the T-stat Housing, there's a Cannister with 2 Large Waterlines,+ 2 Small P/S Oil lines hooked to it.........
That's the Cooler........
I don't know how your Belts run,........
As long as the Circulating Pump,+ the Alt. are turning,.......
I Don't See a Problem...........
Don S
bob
You have 2 hoses coming off the power steering cylinder on the transom shield.
Find the big one and follow it............ it goes to the cooler.
delsol
thanks alot guys'
bob
delsol
it seems like its leaking at the rack behind the new lines. can this be resealed or need replaced. i can disconnect the pump for now as its on its own belt. till i get the other major thinks fixed
bob
delsol
where do you get a rack??? or rebuild kit if their is one
bob
delsol
MER806034A1 Power Steering Kit, New Style, Mercruiser Alpha One Gen. II, Bravo, Blackhawk Power Steering Kit, New Style (metric) Fits Alpha One Gen. II, Bravo, Blackhawk
$159.00
http://bpi.ebasicpower.com/mm5/merchant.mvc?
this looks like my rack alittle . i think i got to use my old metal lines??
bob
delsol
i think i got it backwards i need the pump not the
Power Steering Actuator New???????
is it a 2 part system. the steering works fine pump just leaks
bob
delsol
i ordered a clean used one from ebay cheap..its from a 4cyl eb=ngine took a chance as no one got back to me today. what do you guys think a 4cyl pump???i have a 89 5.7 it come from the same company glastron but 4cly
enclosed pict..
delsol
anyone know if the p/s on the rack is interchangable or rebuilable, i got all new lines and its leaking in the back of the unit.the front seal looks real old. the rack was very rusty.
89 glastron w 5.7 merc
replacement used part from 88 glastron 4cly merc. they look the same
bob
Don S
What are you calling a "Rack" got a picture???
The PS Control unit (your picture) is the same unit for all engines.
But you have me confused. If the pump is leaking, why did you order the actuator/control unit?
delsol
sorry don on the picture their is a hydraulic device on the i where the power steering lines go. in they are new p/s lines...its leaking in the back of the unit. i cannot tell where. can i think the shop put heat on the steering and ruin the device. but the front seal looks old. don i got one on ebay for a 4cyl..will it work. thanks
bob
delsol
anyone???
Don S
You can think that if you want, but if it's a rusted mass, it probably needed replaced anyway.
Huh??????????????
Read the center sentence of my previous reply
