1959 evinrude lark 35 hp cooling question
mchsprky
Hello I have a 59 evinrude lark 35 hp, In neutral i get a good spray of water out the exaust port even when reved really high,but the problem is when i shift into foward it still sprays till mid to wot then it stops if you put your hand over exhaust port fills like it is sucking, I have replaced the impeller the thermastat blew air through nothing is fixing the problem any ideas where the water might being stop from or if water is suppose to come out at wot
tashasdaddy
Re: 1959 evinrude lark 35 hp cooling question
what are you running it in.
mchsprky
I'm running on the lake on guy throttling while i'm looking at motor
F_R
So, are you just concerned about what's blowing out there, or is it actually getting hot at higher speeds?
Only a partial amount of the total water is discharged out that hole. Most of it goes out with the underwater exhaust. At higher speeds, the underwater exhaust is more or less scavenged, so the water just runs out down below instead of a lot coming out the upper blowhole.
If it was actually not circulating at high speeds it would overheat in a heartbeat.
CATransplant
That's perfectly normal behavior for that engine. Once you're under way, all the exhaust goes out the underwater outlet.
larky
I have the exact same engine and mine acts just like yours, perfectly normal. mine has been running good now for a few years acting the same way. When you return the throtle back to idle it starts to spray again.
mchsprky
Thanks for all the replies fairly new to older outboards Just had one more question on were the lower exhaust port is the prop is a sealed shaft with the pickup screen and tube just above the prop no bigger holes were it look like exhaust would come out just small holes thanks
F_R
The snout sticking down aft of the propeller is the exhaust outlet. The water intake screen is on the leading edge of it, exhaust comes out the big hole to the rear.
