200 ocean runner
JMO
Hi i would like to know if anyone can help me.I have a 99 200ocean runner and lately it has been smokin more than normal if i am sitting idle for 5 min or so it will start to smoke not a real lot but enough to notice this is not normal for this engine also when i start it it smokes a lot for a few minutes like clouds it check comp it is good 95 to 100 in all clyd changed plugs filters power pack 9 months ago it is white smoke not black so it is mixing good i think any help i fish 15 20 miles of the shore and i want to know that the motor is ok not something is going to happen soon Thank you Jason
ob
Re: 200 ocean runner
I hear this a lot on vro motors that are several years old.Sounds like the engine is starting up in an oil rich condition.There are a few things can can cause this,Seal leaking between oil and fuel portion of the vro pump,restricted vent on oil reservoir,air/fuel leak on fuel line between tank and inlet of vro pump.
JMO
1 of all thank u and i do notice that i think what is the vro seams to be wet its where the fuel and oil mix how do i fix it i can build a small block chevy for racing all day long but this oil and fuel stuuf is all new to me. do i take it all off and apart or buy a new unit THank u Jason
JMO
does anyone else have any info
Yes - you should do a De-Carb. Likely you have a carbon build up and a de-carb is in order. Find it here under FAQ. It's like cleaning your grill, then cooking the next day. Less smoke ! Get 2 cans of spray. Soak and soak.
Read Dhadleys de-carb FAQ.
mark
