Scaaty
Thread starter- Joined
- May 31, 2004
- 5,180
You PM box is at Max and can't get a PM sent...
you need this latest info..
I went out and checked the set-up for a more accurate description & see that due to the feed into the top carb from the fuel pump that includes the secondary feed to the middle & bottom carb "loop" (that has a secondary fuel feed from the lower fuel pump) that a 90 degree 1/8" NPT male x 1/8" NPT male is required at the top carb with a Tee that is female-female-female 1/8" NPT threaded onto the 90 and then (2) 1/8" NPT male x 5/16 push-on fittings threaded into the Tee.
Then a straight 1/8" NPT male x 5/16 push-on threaded into the top fuel pump.
Hope this infor isn't too late.
