FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
If you check you abs wiring off you rear dif you may fine a brake in the wiring.
Ive seen lots of them.Just pull the harnes apart and pull on the wires to see if the wire insulator pulls apart.If there is just solder them up with shrink tube and you will just fine.
