Cobra Drive Water Output
blueoval1
A quick ? for you cobra guys.
Got a 1988 4.3L cobra setup on a 17ft runabout.
Is it normal for water to run from the exhaust bellows when the drive is on the muffs in the driveway?
I know the new exhaust bellows has the slits in the bottom , but there is no water at all (maybe a trickle) coming out the prop holes.
Thanks for any info! :)
HT32BSX115
Re: Cobra Drive Water Output
Well....I used to be a "Cobra Guy"
Most of the water will run out thru the slits.
Mine ran without an exhaust bellows for about 10 years.
Cheers,
Rick
blueoval1
Thanks guys!:D
Fired it up after installing rebuilt drive and now I gotta rebuild carb.:(
Ahh ! The joys of owning boats!
Thanks again!!
Liquid_force
My '89 does the same thing.
First start on the hose this year I expected to see water pouring out the prop - glad to know coming mainly out the exhaust bellow is fine.
Bought this boat in '03 -- wasn't aware of the shift cable issue and how exact it needs to be, we were learning as we went. Appearently the previous owner wasn't aware either because we went through a set of gears early in our 2nd season.
Since the rebuild just routine maintenance - we've been really happy with it.
