speedometer question
sparticus
As a recent first time boat owner I have many questions. I have a speedometer on my dash (its the only gage there). I noticed on its maiden voyage on sunday that the gage didnt work. No big surprize its a 1965. I followed the black tubing all the way to the back of the boat and it ends in the water. The gage says "airguide". So my question is....... How the heck does it work? Perhaps I can make it perform its function if I understand the principle behind it. I am guessing water pressure but I have been surprized before. I understand that they arent accurate at all and most probably ignore them but its against my nature to see something broke and not at least take a half hearted attempt to fix something. Thanks for the inputs!
Gary H NC
Re: speedometer question
They do work on pressure.Be sure the tube has no kinks or wire ties or anything restricting it.The pitot on the back of the boat has a very small hole in the front edge of it.It may be clogged or the gauge is bad.
Put about 5 psi of air in the tube and see if the gauge moves..
sparticus
Very cool Gary! Thanks. I was tempted to apply some pressure but without an idea of how much I was hesitant. As a technical instructor for aircraft I much prefer technical manuals when doing maintenace but I will wing it (no pun intended) if I have to.;)
diaric
these are usually accurate to about +or- 50 %, but they are cool when they work
QC
FWIW, some of the Airguides are actually pretty decent. I belive they make/made a lot of the Ski boat units that are especially accurate.
Also, I know no one will believe this, but I have had an Alpha and a Bravo, last two boats and they are within .5 - 1 MPH of my GPS . . . day in day out, I am not as lucky in Vegas if you're wondering :eek:
sparticus
Gary. You mentioned a small hole at the front of the tube. Does this mean that the end of the tube is plugged? Mine is open at the end.
Coors
I think you are missing the pitot, that has 3 screws, and is fastened to the transom?
sparticus
So it would seem I am missing the pitot. Anyone have a clue as to where to look to find one? Or......what a boat pitot would look like? A pic perhaps?
bigfoot2184
I did a quick search on ebay and this came up.... looks right to be, but I'm a newbie to this. I'm sorry if posting links is not allowed here. I'm NOT the seller of this item. Just what came up on Google.
http://cgi.ebay.com/ebaymotors/Boat-Marine-Speedometer-Pickup-Pitot-Assembly_W0QQitemZ260128264393QQihZ016QQcategoryZ26451QQcmdZViewItem
F_R
It doesn't matter which brand of pitot you use. The one in the picture is slanted back to shed weeds (yeah, right!!). Nor does the size of the hole matter. I'll now probably be the rest of the day trying to explain why not, but it does not matter.
