Johnson 60 help
thomp1610
My son was given a boat with what looks like a 1965 motor VXL-11C. It sat unused for 8 years. I put Marvel Mystery Oil in the Cylinders and Carb. 3xs over a weeks time. We cranked it over 5x and then hit the choke it started right up. It did pump water fine and smoke to hog heaven for a little bit but sounded very good. I am going to chage the water pump, lower unit oil and fuel lines, but any more suggestions?
F_R
Re: Johnson 60 help
After you do the water pump and fuel tank/hose and gear oil, take it out on the lake and run it. You might get lucky. Sounds like you have so far. Just be alert of any problems and don't head ten miles out in the ocean. There are a lot of preventative maint items to take care of, but first find out what you have.
