ignition switch
lakeloafer
i need a diagram for an ignition switch for 2001 Yamaha 130hp. The oem switch is a sealed switch. If someone could e-mail me one i would be greatfull.
JUSTINTIME
Re: ignition switch
lakeloafer
Re: ignition switch
thank you very much JUSTINTIME your a life saver. now i wont have to use the manual choke to start my motor anymore.
Laram51
Re: ignition switch
Justintime,
While we are at this, I have a 225 yamaha and I seem to have an intermittent problem. The engine at times keeps running and refuses to shut down when I turn the key on off position. Some times it works fine another time I have to disconnect the fuel line and run her out of gas. I see the white wire here is the shut off wire. Do I ground this to the red wire to shut it off? How can I know that the switch is faulty before buying a new one.? Its a 1994 model and uses the usual yamaha multimeter gauges. Thanks
Ray Neudecker
Re: ignition switch
The white grounds to the ground or black wire to kill the ignition. Try pulling the kill switch to help determine if the switch or ground lead are at fault.
lakeloafer
Re: ignition switch
also i have a question on the new switch i bought. there are 2 posts marked with a M, i assume this stands for magnito [sorry for the spelling] or does it stand for something else. Im not versed in electronics. also does the S stand for start or stop. sorry for all the dumb questions.
Laram51
Re: ignition switch
thanks Ray for that info. when I pull off the kill switch it keeps running all the same. Am I to look for a new switch ?
Ray Neudecker
Re: ignition switch
Run a seperate ground from the battery and hook to the ground leads to verify which wire is not making connection.
Laram51
Re: ignition switch
Thanks. Will trying this over the weekend or whenever the problem recurs. Some weekends it's fine. Regards.
