bad gas?
Mutt020
Generally how long would gas last before "going bad"?
Bought my boat, and previous owner stated that it had been sitting for about half a year.
Had some troubles keeping it idling, so carbs were cleaned, new spark plugs installed, and put a new water jacket gasket, and thermostat in it.
Starts better now, but it won't idle. If I keep giving it gas, it'll run fine, but once i let off it'll die. If it idles at all, its only for a few seconds. When its running, there is a pretty good amount of white smoke coming out of the exhaust.
Does this sound like bad gas? I dont know.
tashasdaddy
Re: bad gas?
get rid of the gas and set your idle speed in the water in gear, at 650-700 rpms.
Mutt020
Re: bad gas?
its a 1986 evinrude 200 hp 6cyl. put the correct surface gap plugs in it, i dont recall the model #, but I remember them being the right ones. I would try to set the idle speed in the water, but as mentioned before, it's real hard to get it to idle at all once I let off the gas.
Would the large amount of white smoke (more exhaust smoke than usual)have anything to do w/ the gas going bad? And back to the original question, does gas go bad in that short amount of time (6 mos)?
tashasdaddy
Re: bad gas?
yes, and yes, might even consider cleaning the carbs, as a partial blockage in the low speed jets could also cause your problem. have you check compression?
jammer
Re: bad gas?
I had gas that was over 4 years in my boat when I brought it back out again after my divorce. You can see the motor I run. The motor started and it ran through. Dag on my Johnson is a gas hog..it ate through the tank real quick.
fireman57
Re: bad gas?
If you have white exhaust I would definitely check/change my head gasket. White smoke indicates that you are trying to burn water.
hoeser
Re: bad gas?
White smoke doesn't always mean water but it could in this case... I've found certain synthetic 2stroke oils burn white.
I would get rid of the surface gap plugs, I've always had ****ty idle with them. Find the standard gap plugs suitable for that engine, there should be a part number on BRP as an "alternative" plug.
How many people are actually using the surface gap plugs out of curiosity?
