86 rude bogs down at full throttle,bulb keeps getting inflated then when pumped up and having someone keep pumping bulb while i'm throwing it in gear it will plan of and work fine till all of the sudden it'll bog back down.any ideas?
OK, let's see if we can work this out. is the bulb collaspeing, sucking in? or just getting soft. soft is normal while running, it's only hard for starting cold. someone has to pump it for you to put in gear. and it will plane off, but will bog down. did the person keep pumping? what year? a little more detailed discription would help. have you check spark, and compression. lets see if we can get it to run right.
if it is the pump.where could i find a new one.It's a fuel/oil pump (vro pump)or is the vro pump something different? I know i have one but not really sure if this is it or it's somewhere else like on my oil tank itself.anyway I'm getting side tracked where might I pick up a pump? (rick as far as the plugs go i didn't check after i ran it with the kink fixed,what are they going to tell me?)
