98 Evinrude fitcht 115 will not start\no spark
pipes0000
NO SPARK
Got Gas at fuel rail or presssure lines at motor
Relays are all OK
Checked all fuses
eliminated kill switch
anyother options or ideas are greatly appericiated
and thanks to all the posts:confused::confused::confused:
tashasdaddy
Re: 1998 Evinrude 115 no spark,no start
Welcome to iboats. there are 6 pages of electrical test here, find yours and i don't think the fitcht is in it. but take a look. http://www.boatpartstore.com/page28.asp hate to tell you but the fitcht is a different animal, a few people here are experienced with them.
pipes0000
Re: 1998 Evinrude fitcht 115 no spark,no start
thanks for the link but there is nothing there
i own a automotive shop so i am fairly familiar with diagnostic tests,:confused: but this is a bit different any info on known issues would be greatly appericated,Thanks:)
seahorse5
The coils are triggered by grounding out the 24 volts that are supplied to them. The engine computer, ECU, takes care of that.
To troubleshoot, you will need a DOS laptop with the 1.42b Evinrude diagnostic software, and a serial interface cable, along with the software booklet and the factory service manual.
It's a lot like today's cars that can't be diagnosed without the correct test equipment, scanners, 'scopes, books, and the technical knowledge.
Don't overlook the obvious such as a shorted "kill switch" or a blown fuse.
pipes0000
need a referal to a good dealer in the Toronto Ontario area
and also where can i read user reviews on this motor,,,any suggestions are greatly appericated ,,,also thanks for the replies thus far. Peter:)
pipes0000
bump
Big Keepers
You need to verify if its the ECU or something in the kill switch part. The wire from the key to the ECU that kills the motor.
pipes0000
any idea on how to by-pass the ignition switck \ kill switch??? i think there are 6 wires on the switch:confused:
Big Keepers
I don't know the exact procedure off hand with EFI motors. I suggest getting a repair manual or better yet, the service manual. Older carbureted motors with CD ignition is easy. Unplug the harness from the motor and jump the starter. If it cranks and fires, there is a short or something in the wire probably at the switch. EFI needs power to the computer so you may have a bad relay in there someplace.
pipes0000
thanks for the info
i need to find out exactly wich wires to jump on the kill switch to eliminate it before i take it to a dealer
i have tested all relays and pulled all fuse the only other things it could be is the ecu
pipes0000
Re: 98 Evinrude fitcht 115 kill switch by-pass ?????
bump
Walker
This may help, may not. On a OMC 2 stroke non- fitcht tha kill wire is the black with yellow stripe. It kills the motor by being closed to ground thru the switch. Try just disconnecting that wire from the switch. Open circuit will let a normal 2 stroke run, maybe fitcht too.
pipes0000
tried the black wire and still nothing
so i tried the rest of them 1 at a time and still nothing
i think i will need to have it looked at by someone with the proper scan equipment and knolege
thanks allot for all the info
