4.3 MerCruiser vibrations 1000-1400 RPMs
konrad
Hi everyone,
I just pick up a Larson with a 4.3 aplha one and even if I'm just using the throttle, I get vibrations from about 1000-1400 RPMs, same when it's in gear. Is that normal? My outboard had less vibrations than that. Any opinions will help,
Thanks
180shabah
Re: 4.3 MerCruiser vibrations 1000-1400 RPMs
What year is is??
I believe it was '91 or '92 when GM added the balance shaft to this engine.
Don S
93 was the first year Mercruiser used the 4.3 with a balance shaft. The old ones did vibrate like that.
konrad
Thanks guys
so that's normal, I'm guessing.
Is there any grease fittings on the shaft?
BTW, it's an 89
180shabah
Grease fittings on what shaft?
Balance shaft is internal to the block, so no fittings, But you have an '89, so no balance shaft.
