The motor model number is 9722M. What year is this motor? Also when it is laid down on its "back" gear oil began to leak out of the lower exhaust. I take it that this is not normal. Whats going on and how much to fix? Thanks for the help.
Re: Older envinrude 9.5 hp with leaking lower unit
That is a 1967 model. Typically, the unburned oil from the engine will drain to the lower unit and create some concern. If the lower unit is in fact leaking, the oil will probably have some water mixed in it and should appear creamy and tan.
If the lower unit has developed leaks, seal kits are available here at iboats which will fix the problem.
