jigglestick
Thread starter- Joined
- May 6, 2007
- 25
this is turning into a perplexing kettle of worms of sorts.
I am trying to get this motor running, but my compression check came up sour.
140 - 102 - 102 - 26
the motor has not run for a while and I just installed it last fall.
I was told it was a good running engine by the man I bought the houseboat from.
I can get it to turn over but like you would suspect, it woill only fire real well on one cylinder.
if i can get it to turn over fast enough, it runs. I can tell one cylinder is weak by listening to it.
I was hpoing I have stuck rings from sitting, but feared a cracked block.
no frost plugs are popped out, I checked the cylinders and no sign of water, and the engine oil looks clear, like new, with no sign of water, even after turning it over several times and having it running for about ten seconds, three different times.
now I am having trouble getting it to turn over fast enough to start it again.
GRRRRRR!
I would rather put a different engine in it than try to rebuild it.
I was told parts were spendy.
it's got me scratching my head.
I did take the valve cover off to see if any of the valves were stuck, but everything looks pretty good there?????
GRRRRRR!
