Swampmouse
Thread starter- Joined
- Feb 2, 2007
- 121
I am re-trying this under a different title hoping others will look at it more readily.
Engine is a '83 115hp Johnson.
Ok Guys - I am pretty much finished with my rebuild - MANY THANKS to all of you who have given me very good pointers and walked me through!!!!!
Ok - I got everything hooked up tonight and turned the key......it actually started! (That surprised me a little).
BUT....I saw water pouring out from behind the lower cover where the lower unit/exhaust shaft meets the powerhead. I took off the cover and started again. Water is pouring out the hole just behind/below where the steering unit bolts into the lower unit. What's missing here because I don't think this is normal.
There was no water coming into where the powerhead sits/meets the lower unit inside the main motor cover.
On the other thread someone suggested maybe due to high water pressure on the muffs??
Advice please.
Thanks,
SM
Advice please.
Thanks,
SM
