yourownfree
Thread starter- Joined
- May 30, 2007
- 9
I bought a silverline with the 260HP. I know the guy let it go and now when you pull out the dip stick its way up on the stick milky water oil. I just got it and tried to turn the crank by hand with a wrench, just to see if it was locked up, and it is. Anyhow i suppose there is nothing i can do short of changing it out. I have a 350 trans am motor in good shape. What kind of cam does a guy need to convert or will it work without the change? will a regular 350 bolt up to the outdrive stuff or do i need something to make it work? Or is there a way to figure out where the water came from, could it have come from the intake. It freezes in the area where i purchased the boat.
so it is possible the block froze along with who knows what. What should I do?
