rogerwa
Thread starter- Joined
- Nov 29, 2000
- 2,339
I just bought a 25 ft pontoon with a 92 tohatsu m40D outboard. It was outfitted with a 12 or 12.5P prop.
It starts easily bout when I give it juice, it will either bog and die or if I advance the throttle enough it will stumble and then take off. A smooth advancing of the throttle will cause it to stumble and not rev up to where it should be.
when I do get it to about 1900 and leave it it will lose RPM, like it is flooding or not getting enough I am not sure.. Alone in the boat at WOT, it will do about 4400-4500 RPM. Low I know but it will run consistent. It performs pretty well from 2000-WOT.
The old couple I bought it from never did much to it, so I know I need to at least replace plugs and impeller.
Tips on the problem above?? I am guessing a carb rebuild is in order, but would like opinions on whether it is running rich or lean in the low RPMs..
Any opinion would be great.. Thanks..
