FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
80/6=13.3 (80 gallons of fuel therefore requires 13.3 pints of oil at a 50:1 ratio).
100/6=16.7 (100 gallons of fuel therefor requires 16.7 pints of oil at a 50:1 ratio). Therefore the amount of oil used should be somewhere betwen 1.6 gallons and a little over 2 gallons (8 pints = 1 gallon).
How big is the oil tank ??? My vro tank is 1.6 gallon and over that amount of fuel would be near empty if not empty !!!
If you have a much bigger oil tank then you need to do a little math and work out just how much oil has been used. Then if it is nowhere near enough check out the motor for possible damage from running with little to no lube.
The boaters world guy says that injection systems inject far less fuel mix than the mfg recomendations. This just does not sound right. He said if you were not injecting write amount the warnings would have been going off long ago. This advice just does not make me comfortable.
