Some early 888 questions
Tipsy
I was wondering if anyone knows a couple things? My early 1975 888 with the I drive seems to always have some sort of oddball problem I'm sure I could fix but the Clymer manual sucks when I look for the info on whatever I need. Can anyone tell me which manuals would be the best? What I mean is, which Mercruiser manuals are right for me?
Also wondering if anyone is familiar with the reverse lock valve? Mine seems to be leaking a bit of trim fluid. Does it have a seal in it? The fluid seems to be coming not from the hose connection but instead seems to be coming from the screws on top. I don't just want to start taking it apart until I know more about it and of course my Clymer manual barely acknowledges it's existance. And the other problem I have with this is, I don't want to take it apart before I know if I can get parts. Seems like a lot of what I look for lately is marked as NLA by Mercury. I can usually find it elsewhere but my local marina stores are not much help.
THANKS!!
ziggy
Re: Some early 888 questions
i'm useing c-90-71707 for my 75......
it has the 888 in it too.......
real good book.....ya should get one.......
Tipsy
Thanks! I'll check it out
Haut Medoc
What Ziggy said...
It does have a seal & the reverse lock valve is the pivot for the shift arm....
Your best bet for replacement would be to keep an eye out for a shiftplate of that era on ebay......
Preferably one that has the reverse lockout switch, which is N.L.A. as well........;)​
Tipsy
Thanks Haut Medoc! I'll check e-bay.
Ziggy, is that a Mercruiser part number for the manual?
Haut Medoc
Yes.....
It is a/k/a as manaul #2.....
Manual #1 covers the 888 as well......;)​
ziggy
yes. it's service manual #2
i had me a leaky reverse lock valve on my other 165. i never repaired it. but was able to get o rings for it from my dealer.....maybe a year or two ago....maybe the nla now. i don't know......
ziggy
yep, service manual #1 also covers the 888. though ya need vol. 1 and 2 of service manual #1 to cover the whole thing. drives and specs are in vol 2. engine stuff in vo. 1... that part # is c-90-68648, vol.s 1 and vol. 2.
only reason i think it's manual #2 ya need. is that i'm thinkin that service manual #2 started in 75. they look real similar in the info provided....... service manual #2 is only one book too. it covers all.....no volumes....
if ya provide yer serial # i'd think someone here would be able to tell ya for sure which way to go.
Boomyal
I had a link for the Merc Service manual breakdown. I think it had been saved back when all posted links opened thru an iboats cover. Now when I open it I just get the iboats main forum index.
Hopefully someone else will repost it.
'75-77 888's are covered in manual #2. It is the last Merc manual that has both engine and outdrive in one book. The part number, as Ziggy noted, is c-90-71707. You don't need manual #1.
Tipsy
Thanks everybody. Those part numbers are not coming up at mercury parts Express, but I suppose if I call them they'll know what I need.
Boomyal
Tipsy, keep an eye out on ebay. I got my #2 for about 18$ shipped.
Tipsy
Thanks Boomyal! I'll watch e-bay for a #2.
Thanks again everybody!
Tipsy
One more possible request please,
would someone who has the #2 service manual please look up the "reverse lock valve" for me and give me a proper name and part number?
My local dealer was looking in his Mercury reference and could not find it at all and I thought if I at least had a name or number that might help me to track down the correct o-rings.
THANKS!
