Johnson Water pump
myseanymph
Another question after working on a water pump, do you have to prime it before starting the motor or will it start pulling water immediately?
Thanks for your help
Gary H NC
Re: Johnson Water pump
With the lower submerged or on the muffs will be fine.Do not start it dry..
OptsyEagle
I always like to see the water at least 2 inches above the cavitation plate so that I know the pump is full of water before I start it up. I have no idea if it will self-prime, so I don't take any chances.
Maybe someone else might know about this.
bob131ob
how do you replace the water pump in the lower unit of a 115hp johnson outboard
samo_ott
Post that question in a new thread with the hp & model # in the header for a better response...
