joepauljig
Thread starter- Joined
- May 20, 2007
- 9
I was just wondering if anyone had any suggestions for me. For about the last 2 years my 200 hp johnson has not performed up to previous standards. I have a 1990 Stratos 201 Pro. At WOT, I only get about 5000rpms on guage and about 51mph on GPS. I used to be able to get 6500 rpms and about 65mph GPS. Also, the motor idles fine out of the water, but once in the water, you can barely keep it going at idle speeds. It runs better when on the plane but still not near the speed it had. This has been an ongoing problem for about 2 years. I have installed new plugs, a new coil, and a new power pack. I've also had a cylinder test run and I'm getting good compression on all six cylinders. The only thing I can think of that might help my problem is raising the motor up a little higher by adjusting the jackplate. Is it possible that it has slipped down a little and that's why I've noticed a decrease in performance? If anyone has any suggestions or maybe a different idea of what might be wrong, I would greatly appreciate it.
Thanks again.
Thanks again.
