Hi!
I picked up a 1974 Sea Ray CRV220 with a Mercruiser 888 package last fall for restore. It has the Ford 188hp 302 v8 and (according to my clymer manual) a Mercruiser Model I outdrive.
Long story short: Water was getting into the oilpan so I opened her up, pulled the heads and found one cylinder had a big hole in the Cyl Wall into the water jacket. Didn't really look any farther.
Thots on how this may have occurred?
So, I want to replace the engine. Here are my questions:
I know it is probably better to look for a different boat, but this is likely to be the last boat I will ever be able to have and even replacing the outdrive and motor still make it the least expensive boat I have looked at. Besides I've waited derned near 15 years to get another boat and well, this is my best shot at it.
All help will be greatly appreciated!
Regards!
Rick
- I see a lot of Ford 302 blocks online for 1975 and newer. Will any these mate to my bell housing?
- What range of motor years should mate to this housing?
- I see very few listings online for 888 outdrives but a lot for Alpha -1 and Generation-1 out drives. Since clymer calls this a Model-I drive are these just different ways of naming the same outdrives?
- Any idea what years and outdrive models will fit the transom hole or mounting plates for the 888?
- can a ford automobile block be used if I put in brass freeze plugs and use the marine cam and parts from my old motor?
- anyone know of a good used or rebuilt ford engine to fit this beast?
Regards!
Rick
