Robert16star
Thread starter- Joined
- May 13, 2007
- 14
Hello,
I have the following boat and motor:
Starcraft 16 Camp
96 Johnson model 40TLEDS
The boat ran perfect at the end of last season. It took a bit to get it going two weeks ago but I was finally able to get it running in the drive way. After letting it idle for about 15 minutes the ?No Oil? light and buzzer went off. The oil tank was full. I pumped the Oil tank bulb and let it continue to run. There was plenty of blue smoke coming out of the exhaust. If I shut off the motor and restarted it the ?No Oil? buzzer/ light was off but came back on a few minutes later.
I put it in the water to go for a test run and it seemed to run fine, the oil buzzer/ light didn?t come on. I ran it at top speed for about 10 -15 minutes when all of a sudden the motor shut down. I squeezed the fuel line bulb and was able to get it going only to have it shut down again after a minute or two of full throttle. If I kept at low speeds the motor continued to run and that?s how I made it back to the dock.
I stopped at a marine dealer thinking I needed a fuel filter, and they told me what it sounded like was a possible fuel pump issue. He sold me ($20) a fuel pump rebuild kit (diaphragm etc.) and I?m fairly confident that I reassembled it the same way it came apart. I did have a large ?O? ring left over. Never saw one when I took it apart. I didn?t have an old one laying around after I cleaned up either.
Now the ?No oil? buzzer/light is back on and even at idle the motor stalls after about 3 ? 5 minutes. At the suggestion of my local shop guy I did replace the fuel filter and I?ve started to replace the larger fuel lines on the engine (filter to pump, pump to engine block (vacuum line?), and the line to ?Oil Sight Tube).
Sorry for the long story, I wanted to include as much info as possible. Any help would be appreciated.
Thanks,
Robert
PS If anyone has an exploded view of my fuel pump I?d appreciate the too!
Starcraft 16 Camp
Thanks,
Robert
