gejandsons
Thread starter- Joined
- Sep 11, 2003
- 134
Engine heat alarm still sounds after idling for a few minutes. Water pump impellor looks good by the way. With the muffs on & the water turned on I'm getting a lot of water out various pee holes on the foot but very little out of the exhaust. I'm suspecting a hole in a water jacket or the tube going from the pump to the engine. I placed a rubber hose on the tube that stabs into the water pump & you can blow thru it with no resistance. The air sounds like it is coming out near the area that the flow tube enters the engine. I can't see well enough for a visual inspection.
If the water enters the engine thru this tube, should the 2 exhaust ports & the thru-hub exhaust & the tell-tale be the only places water should be exiting the engine?
1989 Evinrude 110 HP
E110TLCEM
E110TLCEM
