More hp than boat than boat is rated for
bosco83
So I bought a 1960 Johnson 5.5hp outboard yesterday to use as a kicker on my 17' glasply. I also have a small 7' livingston style boat that is only rated for 4hp. So would it be a bad idea to try and use this kicker on the small boat? The Johnson probably weighs about the same or less than the electric motor and battery.
JB
Re: More hp than boat is rated for?
My SportYak II was rated for 3 and I occasionally used a 5 on it, Bosco, but it was a LOT more pleasant to use with the 3.
studlymandingo
Re: More hp than boat than boat is rated for
I'm not too familiar with the smaller HP outboards, but it wouldn't seem that the extra 1.5 HP would be too much. Use the throttle wisely!​
kenmyfam
Being that close I would try it and see. Just be careful.
bosco83
Sounds good I guess I'll give it a try and see what happens.
tashasdaddy
thats a great little engine 24/1` fuel.oil mix. don't go 50/1 or you will have a mass of metal. you can do a complete restore electrical, carb kit, impeller for less than $150. and have a like new engine, without the worry of the old coils failing.
tashasdaddy
also you don't have to use all the hp.
