Boating alone and PFD questions.
RCSConstruction
Back for some more info.
How many of you go out far, alone? What type of safety plans do you have in place? Common sense tells me I should tell people where I plan to be going,have a VHF and backup batteries,flares, and a cellphone. Missing anything?
PFD,Life vest/jacket-
What brand/type do you use? I was looking into one that inflates when it comes in contact with water. It was a 140.00 but seemed like it would be far more enjoyable and alot more comfortable than a vest. How much water does it take to activate? Do they inflate when hit by a big splash or do they need to be submerged? I don't want the thing to go off after a big splash hits me. Are there any slim/light vest's out there that YOU find comfortable and not cumbersome?
Thanks again for your insight.
jonw9
Re: Boating alone and PFD questions.
As a follow up, I see some PFDs are not USCG certified. Is this a requirment for life vests?
bassboy1
Yeah you must also have a Coast guard certified on board. If you come into a situation where the CG requires you to wear one (dangerous water etc) you must don the certified one.
tashasdaddy
i use a stearns automatic inflateable, it has an emergency rip cord, or has to be submerged, to go off. i keep a water proof vhf in a baggie, in the pocket, whistle, mirror. also have built in VHF with 8 ft shakespeare attenna. this is even when alone inshore.
bucky7680
Make sure you use the kill switch and have a way to climb back into the boat if you go overboard. Do a trial run to see if you can get back into the boat by yourself. I use a Mustang self inflating and it needs to be in at least 4" of water to inflate. It cost around $200.
Boatist
When I boat offshore I always wear a Coast Guard approved Life Jacket. I looked a long time before I found one I really liked. Everyone on the boat Wears a Life Jacket offshore. Never had anyone go over board but with 54 degree water it is a big shock when you hit the water. All our offshore Jackets have a whisle attached and Mine has a Strobe light ans signal mirrow,
When boating alone offshore (Rare) I also attach a saftey line between myself and the boat. In the normal summer wind 20 to 30 mph the boat drift is often faster than I can swim.
RCS, I think it depends on the type of boat, the size of the boat and where you are boating among other things. However, Kids need to wear a PFD at all times while underway in all boats, here in NJ.
For example, on a performance boat, it makes sense to wear a CG-approved PDF (standard or inflatable), all the time. On a big cruiser in the bay, an adult who can swim can skip it. When navigating a rough inlet is a small boat, a PFD is a good idea. When alone in the ocean, it is likely a good idea, especially if you are fishing and the water is cold.
I nearly fell out of my 19' bowrider on a windy day in the ocean in November. I was leaning over to wash my hands after baiting up. it would have been difficult for me to swim fast enough to catch the boat, in my workboots.
