Mrk Hollowell
Thread starter- Joined
- May 6, 2007
- 5
I have a 1980 16 1/2' aluminum boat with a 1984 2 cyl. 60hp Evinrude motor.
Was running great, fast as can be--45+mph.
Then, all of a sudden, it dropped to only about 20% of full power--about 15 mph.
It starts fine, revs loud and fast when the start fast idle lever is in the up position. It idles good, it runs smooth at full throttle but with only 20% of the speed. Arghhh!!!
Talked to three boat mechanics.
One said to replace the fuel pump--I did and nothing changed. Same symptoms
The two ignition coils produce strong blue sparks for each plug when cranking and grounding against the motor.
The spark plugs look fine - completely normal...not soaked, not dark, not fould, just normal.
Compression in each cylinder is identical: 148 pounds
Prop tested OK for torque at a prop shop
It runs fine in reverse, though I never go fast. However, it did super rev in reverse while trouble shooting it on the lake a week ago--that's when I thought that the prop was spun--tested OK.
Fuel is new, with the proper 50:1 mix, and has a clean screen filter in the plastic gas tank and a new in-line filter--replaced yesterday when I rebuilt both carbs.
I pulled and rebuilt both carbs yesterday. THe bowls were clean and all jests wer clean.
I started it up after rebuilding the carbs and it ran great with ear muffs--reved incredibly fast. Granted, there was no load on the prop...but it, nonetheless, screamed with no missing at all.
The throttle linkage opens both carbs up all of the way.
The manual and electric choke work as they should.
Took it to the lake this morning and it runs exactly the same as described above; starts fine, revs great in high idle position with fast idle lever in up position, runs pretty smooth at low throttle, but when I move the throttle all of the way forward (Slow or fast), it only goes to 20% throttle and speed. It creates a wake, but it's just not at the power level it was.
When I tried to drop the lower end last weekend, the gear oil was perfecly clear and there were no metal filings or shavings in the gear oil. As I am a novice mechanic, I could not get the lower end to fully disengage so I could not drop the lower end all of the way.
I'm told it could be timing, wiring short, drive shaft spoine worn at lower end or powerhead, air leak in fuel system...
I give up...just about! I just want a nice, fuin boat running again at full speed.
I need a good boat mechanic to diagnose and repair the problem.
Please call or email me.
Thanks for reading this far.
Mark
602-576-3058
mark@markmediagroup.com
Mark
602-576-3058
