FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I just installed a temp/ oil pressure alarm on my 88 OMC 5.7. I was wondering; if I teed in another oil pressure switch into the cooling jacket, would the 5-7 psi switch work ok?, as I don't know what pressure signals trouble.
Pressure isn't going to work on a raw water cooled engine at idle.
But there should be water flow thru the system click here No reason to reinvent the wheel.
Since that sensor is only 1 inch, where would you put it?
EDIT: I see they carry larger diameter ones too...1.5 and 2.0 inch models. The larger ones need a baffle to change when the folw rate acticates the alarm.
Out of curiosity, what is the flow rate at idle of a Volvo SX drive?
Being that I replaced the buzzer with a car horn, I have a dash switch to kill it while starting, etc. As wife and stepchildren use it without me at times, I wan't to be sure an alarm was heard. I can just switch it off until underway
