I need to replace the exhaust flappers in my 1990 OMC 4.3 HO. They melted in an overheat.
First, what are they really called? Exhaust seals? Anti-backwash flaps?
Second, what is the part number, if anyone has the parts book around?
Third, the teardown showed a cracked head on one bank, but not much of a crack. The gaskets showed a very minor difference between the affected cylinders, not the big blowout I was expecting. I had water in both banks, though. Is it possible that I fried the flappers, then shut down too fast and sloshed water into the manifolds? Then when it cooled, it drew water into the cylinders? Everything else looks ok, although I am replacing the thermostat as a precaution. And, yes, the impeller was shot. It was supposed to have been replaced last June when I had the shift cables replaced, but it doesn't look like it had been replaced to me (but I am not an expert by any means).
Thanks
Thanks
