Salmonseeker
Thread starter- Joined
- Jun 11, 2005
- 298
Hey Guys,
The motor is a 2004 Johnson 50HP 2 stroke.
I installed Boyesen Reeds over the winter. I was told that I should be able to lower my in gear idle from 800 RPM to 650 RPM. I installed the reeds and everything seems okay except I cannot get my RPM's lower.
According to my manual the idle adjustment is controlled by the idle timing. When I adjust this the idle rpm does not adjust. I also tried adjusting the idle fuel mixture slightly leaner and richer with no effect.
Is there a way to make the RPM lower on this motor? I believe the amount of air this motor gets at idle is constant and cannot be adjusted. Just the fuel can.
I would like to lower my idle in gear a bit to get my trolling speed a little slower. That was why I bought the reeds. I would rather not mess with the other options to make the boat troll slower.
So is there a way to adjust the idle below factory spec which is 800RPM?
Also I should note that when I tested the boat. Sometimes after a WOT run. When I put the boat in Neutral, the rpms would rise to about 1500 and then slowly come down. This did not happen before I put the reeds in. When this happens the throttle roller cam is not engaging the Carb butterfly valves. So I know it is not a linkage problem. I did mess with the low speed mixture on the carb, don't know if that has anything to do with the problem
Thanks, Jay
Thanks, Jay
