Bow hatch dimensions
markho
can someone tell me the proper dimensions of the bow hatch on a sport 15? the boat i purchesed did not come with one. i am thinking of using non-slip starboard or just might go with the mahagony plywood.
JB
Re: Bow hatch dimensions
Sure, Markho.
It is raining right now, but I will measure it for you and post the dimensions and a pic.
markho
Sure, Markho.
Hey JB, thanks in advance! I was hoping you would reply. I have been looking at starboard and mahgony plywood. it seems that starboard is cheaper online. What would you suggest?
JB
When I got my Striper it had a CDX locker cover, Markho. I found a mahogany ply cover for sale on continuouswave. Othrwise I would have made one.
The dimensions, before rounding the corners, are:
Small end: 16.5"
Big end: 28.75"
Sides: 24.5"
The corners on the small end are radiused at 1"
The corners on the big end are radiused at .5"
Sorry, no pic. It is too big.
markho
Small end: 16.5"
Big end: 28.75"
Sides: 24.5"
I appreciate that big time! that's great info. I was looking online for mahagony plywood and could only find 4x8 sheets, and that's more than i need and a waste of good wood and money.
JB
You know, I think a Montauk cover would work. They are solid teak though, and it probably wouldn't match any mahogany you had for the seats, etc.
markho
true, but neither would starboard.
markho
JB, what about it's thickness?
JB
3/4"
markho
while we are on topic, what would you rather have a wood or a starboard material as a bow hatch? I'm kind of leaning on starboard for easy maintenence. i plan on that surface getting alot of use with fishing. I know that starboard comes in non slip material.
JB
I prefer the mahogany, Markho.
You can't get Starboard to match the "desert tan" of the Whaler gelcoat and white starboard wouldn't look right to me.
markho
i'm kind of torn now between the two. I can't find any links for mahogany marine ply. is this the type i need?
JB
Post a "wanted" in continuouswave's Marketplace for a cover. You can probably get a used one that only needs to be refinished. That's what I did. $30.
markho
good idea, one more question. what's the hinge size? and what metal should i use?
