1991 Fastrike tilt problem
albass
the unit went up and I put the tilt support bracket up then check the fluid then when I went to go up again to take the tilt bracket off she won't go up will run down but makes a weird sound when I try to go up, only down sounds normal could this be a relay or solenoid????
tashasdaddy
Re: 1991 Fastrike tilt problem
run it up and down a couple of times, may be air, from opening.
