Prop Hits the Trim Anode
judavis126
I have a 1986 mercruiser 3.0 135hp Alpha 1 drive and recently purchased a new stilletto stainless prop. The diameter and pitch are the same as the original aluminum prop. The new prop is just a little longer and it hits the trim anode. Does any one know where to get an extended trim anode or have a fix for this problem.
Thanks
chappy190
Re: Prop Hits the Trim Anode
Hopefully you realized this before you started the engine....I would just replace it with a tabless anode. Seems to be the easiest way to deal with it.
Gary H NC
A tabless may create torque steer problems.If it just barely hits maybe you could grind a little off the anode for clearance..
judavis126
I have thought about grinding this anode but im not sure how much the prop will flex under pressure so therefor how much extra do I really need to grind off. I guesse if it does hit it would just break the anode.
judavis126
Will this trim tab work for my motor/drive: Sierra 18-6014
1/4" to a 1/2" Clearence is Plenty....... I think Mine is Less than a 1/4"....
That prop will Flex. Little or None......
cbavier
If the Prop it's tha Trim Tab it might damage the prop and I don't think you would want that. I just looked and mine has 1/2 inch clearance. My Boat is only about 20 ft from me.
delsol
i got this nice prop on ebay ss. it will hit my zinc . if the shop says its ok i will try flat zinc on drive if not get another prop.
bob
ziggy
just grind'er down to fit.......
delsol
zizzy nice picture. i have that exect same problem. the only differece is i got a prop on ebay and never had boat in water and mine will be a clone of yours. i think that will work fine if the bigger prop is ok
bob
Ryan00TJ
Grind the anode down to fit. Next time buy the Merc Hi Performance trim tab anode, it's thinner and made for applications that won't clear an regular anode.
Here's a pic on mine...
