Poor Performance and smoke
CapnLV
Hi Everyone,
I have a 2004 Bayliner 185 that has a Mercruiser engine, 130 HP. I just bought the boat and the first time I took it out everything was fine.
Now I get some blackish/white smoke for the first couple minutes after starting. It also runs very rough and the throttle response is not good. When I have the throttle open, it starts to bog down then speed up again.
I'm thinking its a carburator issue and I really don't want to bring it to a mechanic and spend the money because if it is in fact a carb issue my Warranty does not cover it.
Can anyone suggest something I can try doing on my own before I have to bring it to a mechanic?
Re: Poor Performance and smoke
The Blackish Smoke would lead Me to believe that the Choke needs Looking at.........
CapnLV
Do you know how I would be able to adjust the choke?
Sorry, I'm a newb.
MainstreetUSA1
Is the choke plate remaining closed after the engine is up to temperature? Take a look down the carb throat once it gets up to operating temp. The choke plate should gradually open as it warms up.​
BRG25
Better not let those moths out of your wallet...you must have a bunch of them...
CapnLV
I will check when I take it out after work today. If it does not gradually open is there an easy fox for that?
Windykid
Besides choke, spark arrester is not clogged?
Floats sticking? Smell of heavy fuel?
Check spark plugs for foul?
MainstreetUSA1
Check the wiring for the electric choke. The black wire and the purple wire. Black is ground and purple is power to the choke.​
CapnLV
I think you hit it on the money here man. I am very new to boating/motors, etc...and I was looking at some wires that were disconnected yesterday yet had no idea where they went.
Ayuh,.....
Buy the right Factory Manuals for your rig,............
And,......
Tell Us how much of a Mechanic you are..........
