1983 Johnson 15 Hp
SNOOK115
Motor Starts Easily,,after Motor Warms Up , Will Not Run At High Speed, Bogs Down, Will Only Run At A Idle Speed..... Rebuilt Carb, Changed Fuel Line. Went Out And Tried It Again. Motor Ran Great;;;;;until It Warmed Up... Same Problem Bogging And Only Runs At A Idle Speed. .....what Do You Think .....................
SpinnerBait_Nut
Re: 1983 Johnson 15 Hp
SNOOK, this is the website/froum issues forum.
You need the Johnson/Evinrude repair forum where I will move it to now.
Welcome to iboats.
ezeke
Try running with the cover off to be sure that you are not getting exhaust in the engine compartment.​
When it begins to cut off, assure that you can touch the tops of the cylinder heads for three seconds or more as you may be overheating.​
The high speed orifice in your carburetor may be clogged.
Check your ignition coils for cracks, breaks, melting and color fade.​
