200 hp magnets.
imported_Greenhead
Let;s make sure I did not goof,,,,,,
When glueing them back in. They should be :
NS-NS-NS-NS With N being the north and the S being south where N and S stick together
or should it be
SN-NS-SN-NS
seahorse5
Re: 200 hp magnets.
If you are talking about OMC V6 flywheel magnets, all you have to do is evenly space them with the notched corners facing you (UP).
seahorse5
Re: 200 hp magnets.
when the flywheel is on the crank, should the notches be toward the block or the sky?
to the block
In other words, when you are installing the magnets while the flywheel is on a bench, you want to see the notches facing you.
sweetmarie
Re: 200 hp magnets.
Not to hyjack but I think this question is relevant to the thread. While I was pulling off the flywheel from my 1986 175 hp v6 Evinrude, one of the magnets fell off. None of the magnets were glued and I didn't realize until reading this thread that they had to be.
I put the magnet back to approx. where it was.
Questions: Should I pull off the flywheel and glue the magnets. Do they have to be exactly spaced apart, to the thou? I'm not sure if I positoned the notched corners correctly. Bit I did start the motor and ran it for about 5 minutes.
sweetmarie
Re: 175 hp magnets. 1986 Evinrude
Well I did some reading and found most of my answers: magnet orientation and the need for them to be epoxyed. Guess I'll be pulling my flywheel off again.
sweetmarie
Re: 200 hp magnets.
Just to update: motor's been running smooooooooooth since.
jonesg
Re: 200 hp magnets.
thanks for posting back, thats what makes this thing work.
