awalkertx
Thread starter- Joined
- Apr 16, 2007
- 19
Brand new boat (other than a jetski) owner here... hunted and found exactly what i wanted: just bought a mint ~250 hour 1997 cobalt with a 5.7L and a duo-prop out drive. and I am VERY afraid I screwed something up in the boat's first outing with me at the helm.
first: trim works but trim indicator does not.
second: i ran the drive in all sorts of different trim scenarios and at all RPMs. After re-reading the manual, I can see stringent RPM limitations for the drive when it's beyond certain angles. I know for a fact that I blew through those.
last: i have learned that the tilt switch does not need to be depressed for the motor to move up. i guess it defaults to no safety when the trim sensor isn't working.
There was no catastrophic failure, but I remember the outdrive getting very noisy as I trimmed up past a certain point... i'd immediately trim back down but I was waaaay over the 1000rpm limit. Was the u-joint the main recipient of the beating - or something further in the outdrive?
Any ideas for this idiot/novice boat owner? What should I do - what should I check? have I totally screwed up (or vastly decreased the life expectancy) of the out drive?
Thanks VERY VERY much for any help you may be able to give.
Adam
adamwalker@gimail.af.mil
Adam
